Job Queue doesn't run automatically
I’m trying to schedule some repetitive task using the Job Queue. I create a new entry with a code unit that i created for test :
Vendor.GET (‘FRE-0389’);
Vendor.Name := ‘Modification Done’;
Vendor.MODIFY;
My problem that this entry doesn’t run automatically, every time i should execute the Code Unit 448 -Job Queue Dispacher - to make it running.
How can i fix that ?
PS: we are using Dynamics NAV 6.0 R2.
regards;
Do you have NAS configured and setup for JOBQUEUE? There are a few posts regarding that .
g.
Thanks for your reply faludigabor,
i’m running the NAS on my PC and the RTC works fine. I followed many articles but i didn’t notice the problem?
regards,
HI,
what is the Frequency mentioned in the Job Queue Entry Card form? also check the earliest start date / time. the queue runs based on this field.
Regards
Sharran
Try setting the “TableNo” property of the codeunit to “Job Queue Entry”.
I had a similar issue that was solved like that.
Best Regards.
Hi ,
You should ensuere that the user that runs NAS has windows login access. I also rememmber that the Codeunit 1 had to be amended to pickup JOBQUEUE.
g.
Jose Monteiro > I tried this too but it didn’t work? i still should execute the -Job Queue Dispacher - to make it running ?
regards
You should configure NAS with the parameter JOBQUEUE then you dont need to run anything manually.
Again , have you set up properly nas ?
Here is a link for example :
http://blogs.msdn.com/b/microsoft_dynamics_nav_sustained_engineering/archive/2007/12/19/how-to-set-up-job-queue-in-microsoft-dynamics-nav-5-0.aspx
gabor
I suggest that you start testing it without the NAS directly by running codeunit 448 (Job Queue Dispacher) directly (from the classic client).
