Is there anyway to automate Job Journal postings from the General Journal entry.
Hi Andrew
If you are asking if this is possible in Standard Navision then the answer is no. You will have to customize Navision to achieve this.
Regards
Claus
Thought as much, I couldnt find anything from any of the menu’s. Thanks
You are welcome.
Hi Andrew
I was just going to ask the same question and thought I would do a search first, Did you get anywhere with this ?
Bob
