when I start the production order
www.hostingpics.net/viewer.php
in the General tab, there is the “Route card journal” and “Picking list journal” the “job card journal” does not exist
please why ?
please why ?
HI Mechri,
As per my knowledge, Ax will create only picking and route journals automatically.
Job card journals should be created manually.
please correct me if I am wrong.
regards
guru.
Hi Guru,
yes you are right
Thank you
Job journals can be created automatically if you setup the system to undertake job scheduling, and they are mainly used for MES logging on and therefore you ideally need them configured and MES configured.
