In Project Management and Accounting
Common - Item task- ITEM REQUIREMENTS
While creating a new record, the first field is PROJECT ID, This by default shows all projects. Is it possible that i can filter this lookup list, based on a Condition say Project group = X . Only in this form. I don’t need the filtering to happen if in the user goes to Common- My Projects-- Item requirement. or Common - All Projects - Item Requirement
In a nut shell the lookup should filter only in Common - Item task- ITEM REQUIREMENTS; not anywhere else
Thomas
