Hi All
In AX 2012, do we have a report on production, that tell me for a product (Finished item) in one month,say, how much the raw material is consumed. And if Possible for the particular customer.
Hi All
No not out of the box for what I believe you require.
that means we can not generate the report for the raw materiel consumption for the particular finish good for a particular time period.
Imran , Do not post the functional realted questions under AX - Technical forum. I suggest you post under AX -End user forum , then you would get the more answers from the functional team also
Why do you want this?
You can see consumption posted by production order, you can see the consumption of a raw material, you can see on the analysis report the range of dates for a product for all production orders. You want one report with one order to show all consumed elements of the BOM in a period - why? I suggest if you want every report exactly how you want it out of the box you will be disappointed, MS have utilised SSRS so you can write your own because the out of the box reports meet 10% of the average clients needs. I could almost answer any report question with “No” because when you get into the detail something is missing. Essentially you CAN generate a report for raw material consumption for a particular finished goods for a particular period when you utilise the elements of AX and write the report to do what you want it to exactly do [:D]
Ok Thanks for the information.
That i know, all the requirement can not be fulfilled by the standard report in AX that we can achieve from the SSRS, but i though may be what i require is already there that is why i put it on the form.
