Issue with writing/reading blob field to and from the table
I’m using business central online.
My table has a blob field and I need to store web API authentication token into it.
When I make a call to web API for the first time, I store the generated token in the table so that it can be re-used next time when I make a web API call.
When I try to read the blob field from the table, it is always empty.
Here is my code.
// store token in the table
Config.“Current Auth Token”.CreateOutStream(OutStr);
OutStr.WriteText(‘test token’);
Config.MODIFY();
//Retrieve token
if(Config.“Current Auth Token”.HasValue()) then begin
Config.“Current Auth Token”.CreateInStream(InStr);
Instr.ReadText(token);
End;
I was missing CALCFIELDS before creating the InStream object:
Config.CALCFIELDS(“Current Auth Token”);
