This is a known issue, and I, either can’t seem to resolve it with the KB resolution, or there’s a different issue. Hoping the grup may help.
“In version 5 you will get the message. In NAV 2009 you won’t. This has one specific implication in the standard application. Most matrix forms have a function called “DimCodeToOption”. As an example is Form 113 Budget. The function has a parameter “DimCode” which in version 5 was type Code. This has to be changed to Text. Otherwise, the case sensitive comparison will fail, and Matrix forms will not show any data. So make this change in Form 113 and other forms, for example Form 554 “Analysis by Dimensions”. And if you find other matrix forms have stopped working, then check this first.”
I am struggling with FORM 7139, which is a matrix form (I believe), and I don’t see that it has the function that is talked about above. However, this form does not populate with any of data. I would expect it to populate with items, but it does not. Hence I thought this issue above was the culprit… In my 5.0 SP1 Db, this object does not have a dimcodetooption ???
Anyone?
