I have consumed a web service using visual studio and used managed code to call that in AX 2012.
Now if I running the code in a simple job as:
static void CurrencyService(Args _args)
CurrencyConvert.Currency_Convert.CurrencyServiceClient convertcurrency;
CurrencyConvert.Currency_Convert.Currency currency;
System.ServiceModel.Description.ServiceEndpoint endPoint;
System.Type type;
System.Exception ex;
str s1;
try
type = CLRInterop::getType(‘CurrencyConvert.Currency_Convert.CurrencyServiceClient’);
convertcurrency = AifUtil::createServiceClient(type);
endPoint = convertcurrency.get_Endpoint();
// endPoint.set_Address(new System.ServiceModel.EndpointAddress("">localhost/HelloWorld"));
currency = convertcurrency.GetConversionRate(CurrencyConvert.Currency_Convert.CurrencyCode::AUD,CurrencyConvert.Currency_Convert.CurrencyCode::INR );
info(strFmt(’%1’, CLRInterop::getAnyTypeForObject(currency.get_Rate())));
catch(Exception::CLRError)
ex = CLRInterop::getLastException();
info(CLRInterop::getAnyTypeForObject(ex.ToString()));
Above job is working fine and producing results in a infolog.
Now, if a same piece of code is written under a class for batchjob(extending Runbasebatch class) as we normally do for any batch job, it is throwing an error as:
Microsoft.Dynamics.Ax.Xpp.ErrorException: Exception of type
‘Microsoft.Dynamics.Ax.Xpp.ErrorException’ was thrown.
at Dynamics.Ax.Application.BatchRun.runJobStatic(Int64 batchId) in
BatchRun.runJobStatic.xpp:line 38
at BatchRun::runJobStatic(Object[] )
at
Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type
type, String MethodName, Object[] parameters)
at BatchIL.taskThreadEntry(Object threadArg)
Other batch jobs except which used web services are working properly.
I have already tried many things such as : RunOn property of a class is set as “server” etc.
This is the case with each web service we have consumed.
Does anybody have a proper solution for this??
