Dears i need your help, i need to know why this message appear to me in AX, and how can i solve this issue
Field ‘End time’(=-1) can only contain positive numbers
Field ‘Last time’(=-1) can only contain positive numbers
Field ‘Start time’(=-1) can only contain positive numbers
Please your help guys
adamz
#2
Hello, I am getting the same issue, please assist if you have found the cause of this error…
What exactly you are doing, could you give some repro steps?
adamz
#4
I went to Basic > Number Seqences > Number Sequences (NumberSequenceTable)
If I try to edit the fields of some of the records I am getting this error:
Field ‘Time’(= -1) can only contain positive numbers.
(Not for all the records though, it will not save, and cannot close the form until I restore the original values.
Any help is appreciated
adamz
#5
I also noticed that for those records the DEL_LatestCleanTime is ??? but for the ones that I can edit is 00:00:00
