ISO XML 20022 for communication with bank
Good morning everyone
I just arrived at a company, at their financial department, and they gave me a task which is a bit big for me, however I have been instructed to do it or to advance on it as much as possible, and I would like to have some advice from you on this since my knowledge of Dynamics AX is not that high at all.
We want to automatice some processes with our bank by moving payment info from AX to our bank and bank statement from our bank to AX (They are doing it manually one by one at the moment, takes long time). We were told by our bank that the only way is using XML files (ISO XML 20022 specifically) and I don’t know what tool in Microsoft Dynamics AX 2012 r2 I should use to at least start with this apparently big proccess.
I don’t even know if I have to install some specific tools or add-ins, although I’ve been told to install “ER engine“ to use XML with AX but I can’t even find anything like that that I can use in MD AX 2012 r2. Could anyone help me or give me a tip perhaps?
Thank you a lot in advance, and sorry for the messy way of explaining this, please ask me if I said something wrong or I missed some info and I will answer fast.
Best regards,
Jorge
There is a whitepaper called SEPA (ISO 20022 XML) credit transfer payments. I don’t know much about it, but take a look at it and ask questions here if needed.
There are more whitepapers and walkthrough configurations in the technet links provided below, it is bit deep and interlinked with other configurations.
Dig a bit to check/understand the existing configurations first on where your current system actually stands.
Is vendor & Customer payments and formats, customer payment settlements, vendor payment settlements are pre-configured already ? That might help you get going with the process.
Credit transfer payments
technet.microsoft.com/…/jj571732.aspx
Direct debit payments
technet.microsoft.com/…/jj571733.aspx
Configuring AIF outbound integration port for payments
technet.microsoft.com/…/hh446522.aspx
Hope that helps.
Thank you very much to both of you.
I started with that pre-configuration since there is some missing data for some vendors that is neccesary according to the PDF you both sent… and because there are many I have to do it manually one by one and send the gathered data to someone with clearance who can insert it.
It will take a while, so I will continue with it and then I’ll move to further steps, thank you very much again.
Jorge
