Hi all, I defined option variable on my form. And I set data in OptionString property? I use this variable as a textbox’s SourceExpr. I want to use Navisions MultiLanguage property. is option variables CaptionML property? Regards
You should set CaptionML on textbox’ property OptionCaptionML
quote:
It didnt work.
For defined option variables navision has three property OptionString, OptionCaption, OptionCaptionML. If you set OptionCaptionML it will work for multilanguage purpose but you need also set OptionString property.
quote:
Thanks Fevzi. I was trying to configure variables property. I configured textbox’s property. It solved problem.
