Is it possible to use COMPANYNAME function to create storeprocedure in SQLSERVER
Create Procedure [dbo].[ COMPANYNAME $ CreditAcc]
@InvoiceNo nvarchar(20) = null,
@InvoiceLineNo nvarchar(20) = null
As
Begin
// Sql statement used in the stored procedure
End
What you want to do here?
You want to create a storeprocedure named " [dbo].[ COMPANYNAME $ CreditAcc]" ?
Or by calling “COMPANYNAME " withing " [dbo].[ COMPANYNAME $ CreditAcc]” you want to get current company name?
what ever it is here is the answer :-
Hi Sriyantha
by callling “COMPANYNAME” within " [dbo].[ COMPANYNAME $ CreditAcc]" I want to get the current company name to be replaced by “COMPANYNAME”.
e.g.
IF current company name is “DynamicNav” then after executing this query i.e.
As
Begin
End
the name of the store procedure should be
dbo. DynamicNav $ CreditAcc
PS: “COMPANYNAME” function is being used by Navision that holds current name of the company. I want to get the value of “COMPANYNAME” in SQL to create a new storedprocedure in the name of company.
Also I tried your solution already but it doesn’t replaces the value which “COMPANYNAME” function has… in the query.
