Is there a windows registry key that can be modified so I change the fonts use in the C/AL editor ?
After more than a decade using certainly the worst developer font ever, I thought it’s about time to switch to a nicer developer font (if that’s possible!)
Any tips and advice for achieving this are welcome
The method described in this thread (Girish Joshi’s entry) should do it.
I don’t know wich font is used in the C/AL-editor though, so i can’t tell you wich entry to modify/create.
Yes, correct.
However i think that Tarek, as a freelancer, works with several older versions, and developing objects for e.g. 3.70, using a NAV2009-client could result in (by accident) using some command that isn’t avaiable in 3.70 (FINDSET could be one)…
If you feel that one of the replies answered your question, then please click on the verify solution button next to the post. This way we know that the thread is closed and it’s your way to credit the person who helped you.
