AX 2012
Is it possible to automate the product receipt number so it automatically uses the next available number?
AX 2012
No, because that is the number provided by the vendor as a GRN number and is therefore generated by the vendor, if you were to fill it in you would not be able to provide the vendor with the number it was received upon, just the PO number, which gives you issues with part deliveries, and when they do not track your PO number.
