Dear All,
I have installed NAV 2013 in server and now i want to connect the server from the client PCs. Is it compulsory that the users must be in same domain or jst same internet connection is enough?? i have created the logins with the sql credentials and also users in the nav database but whenever i try to login with my credentials i get this error which i have attached here in this post. i am not getting where am i getting wrong in the setup. i have setup “UserName” in Clientusersettings.
Suman
You need add the users in NAV2013 RTC under
CRONUS Nederland BV/Departments/Administration/IT Administration/General/Users
You can login to database with Windows from which you have installed.
if not, try this blog
http://blogs.msdn.com/b/nav/archive/2012/10/03/manually-restoring-the-nav-2013-demo-database.aspx
Thanks Mohana and Saurav Dhyani…
You guys saved my day…!!!
Suman
Hi Saurav,
One more question as i am new in NAV 2013, will the user as i have created using “NAVuserpassword” be created in SQL or not??
It might be a sily question but i am a beginner in NAV 13 setup so it will of great help to me.
Thanks & Regards,
Suman
