Is AX 2009 to AX 2012 R3 CU8 Upgrade possible?
If possible please explain in steps?
If Not possible explain me the steps in another way?
Hi Anand,
Thanks for the reply.
My another query is
if i upgrade ax2009 SP1(Source) to AX2012 R2 (Target)
After that, Can i upgrade AX2012 R3 CU8 in the target system itself?
Yeah you can go with the source to target model approach to upgrade from AX 2009 to AX 2012
And in-place upgrade for AX 2012 R2 to AX 2012 R3. FInd detailed explanation in the below link.
Note that you can upgrade AX 2009 SP1 directly to AX 2012 R3. If you don’t have a very good reason for splitting the upgrade to two separate upgrades, don’t waste your time and do it all at once.
Hi Martin,
I want upgrade from AX2009 SP1 to AX2012 R3 CU8 Upgrade. If it possible, Please share me the links.
You can download the upgrade guide from here
@ Martin–
I am doing upgrade of Ax 2009 to Ax 2012R3 Cu8 in Contoso Environment.
Below are my queries.
1.) My application version is 5.0.1500.4570 and kernel version-5.0.1500.4570
i.e SP 1 and Roll up 7.
Is it possible to upgrade it in Ax 2012 R3 CU8?
I have done steps in Source system and while doing target system part i got 2373 errors in Compilation( AOD upgrade checklist).Let me know if we need to solve this errors.
If anyone has any step by step approach apart from MS guide please share.
Manas
Yes, it’s possible. It’s been already answered above.
Perform a code upgrade to make your code from AX 2009 working in AX 2012.
Hi Anand,
The links you’ve provided seems to be broken can you check it and let me know
Hi Martin, Can you provide me with a link or any documentation for direct up-gradation from 2009 to 2012 R3.
That would be so helpful.
Thanks in advance.
The link works fine for me.
If needed, you can always use your favorite search engine to find the AX 2012 Upgrade Guide.
