We are facing very critical problem in our inventory.
We recevied item1 of quantity= 301.320 through purchase order and when we print packing slip it shows same quantity i.e. VendPackingSlipJour.Qty or VendPackingSlipTrans.Qty = 301.320 BUT when we see the item transaction i.e. Item1 transaction, it shows InventTrans.Qty = 2853.040 (which is our total quantity of an item1 in purchase order).
This difference in InventTrans.Qty and VendPackingSlipTrans.Qty makes a huge difference in Finance.
I would like AX technocrats to please help me on this issue.
Can any one guide me where I can find this calculation of InventTrans.Qty and VendPackingSlipTrans.Qty transaction.
Check INV.UOM and Purch.UOM on item master details for the specific item and also you can observe the same in Purch line level
Based on Inv UOM and Purch UOM >Righclick > go to main table form > setup > select Unit conversion> here you can find the calculation in between two units in Unit conversion form
I checked item’s both Unit of Measurement (Inventory & Purch) and it is same i.e. M2. I also checked if there is any unit of conversion for this item but found nothing.
