hi,
i am trying to run the recaluculation for a period of 1 year and i have almost used out 100 hrs but still no signs of completion.
What could be the problem?
How do i resolve this?
regards
dinesh
hi,
regards
dinesh
Try to run Inventory recalculation for the smaller periods and see if AX completes the Inventory recalculation.
I would suggest you to run the Inventory recalculation with multi users option, where multi clients will be running Inventory recalculation which in turn completes the recalculation in a faster manner.
Satish EC
Hi satish,
DO you mean in the network environment user multiple seasons to run the recaluculation.
As i understand the instance can be only one but you can only open the other season to use inventory help to speed up the process.
If you can through in a little better light on this it would really be greatfull.
Also do you have any idea of what is the values i need to give for the following.
Maximumb throughput (5)
Minimum throughput adjustment (1)
minimum settlement quantity percent (10)
minimum settlement amount : (5)
the values indicated in the brackets are the one which we have currently set.
regards
dinesh
Hi Dinesh,
for multi user closing:
In one terminal run the Inventory recalculation, in other terminal go to Closing and Adjustment screen, calculation–>Inventory help (start calculation).
What is your costing method your Inventory?
Satish EC
