While doing the Transfer order from one warehouse to another warehouse with in the site, the system calculated the Physical cost amount as 150 rs for 15000 qty, where as in Financial cost is showing as 2 crores.
Before doing transfer order, i did production order for that particular item, at that time that values are coming out correctly.
While transferring only the values are different and the adjustment amount is showing zero only.
After completion of production order only i did the Transfer order. And i did the recalculation also, but still the financial cost amount is showing higher value.
As suggested by Adam, run inventory close also. Inventory recalculation is not that reliable. Also increase the through put also to get more accurate result.
