Inventory movement
What is the report available in Navision to track the item movements with warehouse.
What about movement analysis report in Navision?
Is it available in Navision as default or do I need to customize ?
thanks
That really depends upon what you mean by tracking, are you in true warehousing? Are the transactions posted or are you looking at warehouse shipments etc? Do you use dimensions? If you do have you looked at the analysis tools Navision will give you some base reports? but for regular necessary reports they are written specifically for the customer. Have a look at report 704 as a starting point.
Can you define better what your goal in analyzing warehouse movements? Most Navision reports are value based.
Most users to view warehouse movements use form 7318 – Warehouse Entries
thanks u Adam, Nuno,
Sorry for that I have written some mistake.I want the inventory movement with out ware house.Thanks and regards
With Sales analysis reports and purchases analysis reports you should be able get good reports.
Thanks Adam roué and Nuno,
I got what I want from Adam roué . I want this report 708.
regards
