Inventory management - can it handle rentals
I got a question the other day if NAV 2013 could handle that you rented out your inventory (i.e. not selling it). I said that it could but going over the documentation I have, I cannot see that it does. So now I am asking you guys, can NAV handle renting out stuff?
Thanks for your help.
Magnus
PS. You don’t have to explain how it works but just if it does or not.
I think you can by creating seprate location as’Rental’ and transfer the Inventory in that location.
Hi Magnus,
No, NAV 2013 doesn’t have rental management as a standard module. So while you might be able to handle it if rentals are not your main business, using locations etc. as a workaround, then if rentals is a more important part of your business, then you should look for a rental management add-on for NAV.
There are many rental add-ons available for Dynamics NAV in many countries, the only question is if there are any which already has been developed and tested for Dynamics NAV 2013?
Hi Erik,
This is what I suspected. However, I do think we can solve it the way Amol said (or in similar way suggested by a consultant on our side). Thank you both for your help.
Magnus
