My client received the following problem when they run the Inventory-G/L Reconciliation report in navision 6.0:
When we run the Invent. G/L Reconciliation report and, In some cases, when almost all user are connected to Navision, after 3 or 4 hours of processing it is causing a crash of the database server
All user connected to navision in that moment loosed connections to Navision.
We reviewed the log entries of SQL server and found this entry : LazyWriter:warning no free buffer found.
We tried to stop the sql service from Service Manager , but it doesn’t work
We had to turn off the Server Machine ( it was the only way). Then we turned on again the Server Machine.
And we run the report directly from Navision Server and it took approximately less than 2 hours
Please suggest some solutions.
Thanks.
