I perform an Inventory Adjustment and when I post the transaction I get the “Number sequence 0 does not exist”.
I have removed the number sequence and re-added it and it still occurs.
I’m patched to the current version.
I’m out of ideas. Anybody have any suggestions?
Check the number sequence scope. This is known issue.
I am not 100% sure but we got solution by changing the scope to shared from Company (or Company to shared). Try this.
Pranav…
I found the problem regarding the ‘Number Sequence 0 does not exist’. I found that my Voucher Series on the Journal Name was set to Unknown. I deleted and recreated the Journal Name and used the correct voucher series that is in the Number Series for the Inventory Jounral. Once I did that the error went away.
Now when I post the Inventory Adjustment I get two new errors that I can’t find a solution on.
- Account number for transaction type Inventory, inventory receipt does not exist.
- Account number for transaction type Inventory, inventory profit does not exist.
I go to the Item Group for this item and both have a valid Account Number and are active and not suspended.
Any suggestions on this new issue?
Thanks again.
Solution: Once I activated the account structures all my issues went away. General Ledger > Setup > Chart of Accounts > Configure Account Structure.
Thanks all for your help.
