Internal Error 100 in Module 11
Hello all, I just started working with Navision, and when I am in the main menu and click on the financials button, I sometimes get an Internal Error 100 in Module 11 which translates into this if I am correct: 11-100 #Err_Att_Undefined (Module_Att,Err_Allowable(100)). Can anyone help me with this? I can’t really make out what kind of error i am dealing with here… Thank you very much in advance Kind regards, Robin
From the Navision site: Internal Error 100 in Module 11 Missing Attribute. There is an attribute (a property) which the system is expecting to be there, but which is not there. First published: Wednesday, September 06, 2000 Last update: Wednesday, September 06, 2000 Document ID: 10538 Missing Attribute. There is an attribute (a property) which the system is expecting to be there, but which is not there. If development is happening on a live system, this could easily happen. Especially if a user is trying to run an object that the developer is in the midst of changing. Try closing Financials and opening it again (to clear the object cache). Another common situation for this to happen is when you attempt to print. This may mean that there is a property missing in the printer itself. Try running the printer setup, or switching to a different printer driver. Chris Krantz NCSD,NCSQL,MCSD,MCSE Microforum Inc. Toronto, Ontario, Canada
Hey Chris
What do you mean by “Try running the printer setup”?
I got this problem when trying to print from NAV.
I have tried to restart NAv which did not help. I also tried another printer which worked.
But the printer I want to work with will not!
Michael
