Interesting Problem with Dataport Exports (Referenceing Forms 302 & 10007)
Hello all…
I am having trouble with arrays and doing a dataport export. I am using the above 2 forms as samples. The version of Form 10007 that I am using has been modified from the original from a third party.
The end result is that I would like to export information that I find in the Form within a Form screen when this is running. However when I re-create the same code in a new dataport and then try to export the information, I even define the variables the same way.
The problem is that when I try to run the code, it gives an error about how I am defining the variable with too many demenisions.
I’ve also tried re-writing the logic so that I don’t have to use an array. But it just doesn’t work at all, it’s too daunting of a task. Is there something that I am missing? I am using Microsoft Dynamics NAV 4.0 SP3
Basically the code that I am after is a calculation for balances of different companies currently(workdate being used to establist current), after 30, 60, 90 Days(previous to workdate) any amounts or credits owed at that time.
I am using this information to put into a formatted file that I will be sending to a credit agency. such as experian or d&b. Any help would be appreciated.
The other thing that is very hard to do without an array, is figure out how long the average length of time it takes to have a company pay their bills.
Thanks in advance,
Kevin
Moved from the Beginners forum to here, probably more likely to get an answer.
Kevin,
What is the exact error message you are getting? Also, do you need average days to pay for all of the periods defined (current month, YTD, Last Year)? A dataport might not be the correct choice here, you might want to consider modifying the Aged Accounts Receivable report to output to a text file and add the average days to pay calculation to the Customer dataitem.
Hi Kevin,
I had a go at knocking up a dataport from form 302, and here it is. its not complete but hopefully a starting point for you. As always E&OE it was only a quick go.
I still can’t work out how to add the “code” tag in here.
OBJECT Dataport 50000 Exp Form 302
OBJECT-PROPERTIES
Date=12/01/07;
Time=16:27:56;
Modified=Yes;
Version List=;
PROPERTIES
Import=No;
DATAITEMS
{ PROPERTIES
DataItemTable=Table18;
DataItemVarName=CustomerFilters;
OnPreDataItem=BEGIN
CurrDataport.BREAK;
END;
FIELDS
{ PROPERTIES
DataItemTable=Table2000000026;
DataItemTableView=SORTING(Number);
OnPreDataItem=BEGIN
Customer.RESET;
Customer.SETVIEW(CustomerFilters.GETVIEW());
SETRANGE(Number,1,Customer.COUNT*6);
Customer.FIND(’-’);
ExportText[1] := ‘Payment’;
ExportText[2] := ‘Invoice’;
ExportText[3] := ‘Credit Memo’;
ExportText[4] := ‘Reminder’;
ExportText[5] := ‘Financial Charge Memo’;
ExportText[6] := ‘Refund’;
END;
OnBeforeExportRecord=BEGIN
X += 1;
IF X = 7 THEN BEGIN
IF Customer.NEXT = 0 THEN
CurrDataport.SKIP;
X := 1;
END;
IF X = 1 THEN BEGIN
WITH Customer DO BEGIN
//CLEARALL;
NewClearAll;
FOR j := 1 TO 6 DO BEGIN
CustLedgEntry[j].SETCURRENTKEY(“Document Type”,“Customer No.”,“Posting Date”);
CustLedgEntry[j].SETRANGE(“Document Type”,j); // Payment,Invoice,Credit Memo,Finance Charge Memo,Reminder,Refund
CustLedgEntry[j].SETRANGE(“Customer No.”,“No.”);
IF CustLedgEntry[j].FIND(’+’) THEN
CustLedgEntry[j].CALCFIELDS(Amount,“Remaining Amount”);
END;
CustLedgEntry2.SETCURRENTKEY(“Customer No.”,Open);
CustLedgEntry2.SETRANGE(“Customer No.”,“No.”);
CustLedgEntry2.SETRANGE(Open,TRUE);
IF CustLedgEntry2.FIND(’+’) THEN
REPEAT
j := CustLedgEntry2.“Document Type”;
IF j > 0 THEN BEGIN
CustLedgEntry2.CALCFIELDS(“Remaining Amt. (LCY)”);
TotalRemainAmountLCY[j] := TotalRemainAmountLCY[j] + CustLedgEntry2.“Remaining Amt. (LCY)”;
END;
UNTIL CustLedgEntry2.NEXT(-1) = 0;
DateFilterCalc.CreateAccountingPeriodFilter(CustDateFilter[1],CustDateName[1],WORKDATE,0);
DateFilterCalc.CreateFiscalYearFilter(CustDateFilter[2],CustDateName[2],WORKDATE,0);
DateFilterCalc.CreateFiscalYearFilter(CustDateFilter[3],CustDateName[3],WORKDATE,-1);
FOR i := 1 TO 3 DO BEGIN
CustLedgEntry2.RESET;
CustLedgEntry2.SETCURRENTKEY(“Customer No.”,“Posting Date”);
CustLedgEntry2.SETFILTER(“Posting Date”,CustDateFilter[i]);
CustLedgEntry2.SETRANGE(“Posting Date”,0D,CustLedgEntry2.GETRANGEMAX(“Posting Date”));
DtldCustLedgEntry2.SETCURRENTKEY(“Customer No.”,“Posting Date”);
CustLedgEntry2.COPYFILTER(“Customer No.”,DtldCustLedgEntry2.“Customer No.”);
CustLedgEntry2.COPYFILTER(“Posting Date”,DtldCustLedgEntry2.“Posting Date”);
DtldCustLedgEntry2.CALCSUMS(“Amount (LCY)”);
CustBalanceLCY := DtldCustLedgEntry2.“Amount (LCY)”;
HighestBalanceLCY[i] := CustBalanceLCY;
DaysToPay := 0;
NoOfInv := 0;
REPEAT
IF j > 0 THEN
NoOfDoc[i][j] := NoOfDoc[i][j] + 1;
CustLedgEntry2.CALCFIELDS(“Amount (LCY)”);
CustBalanceLCY := CustBalanceLCY - CustLedgEntry2.“Amount (LCY)”;
IF CustBalanceLCY > HighestBalanceLCY[i] THEN
// Optimized Approximation
IF (CustLedgEntry2.“Document Type” = CustLedgEntry2.“Document Type”::Invoice) AND
NOT CustLedgEntry2.Open
THEN
IF CustLedgEntry2.“Closed at Date” > CustLedgEntry2.“Posting Date” THEN
UpdateDaysToPay(CustLedgEntry2.“Closed at Date” - CustLedgEntry2.“Posting Date”)
ELSE
IF CustLedgEntry2.“Closed by Entry No.” <> 0 THEN BEGIN
IF CustLedgEntry3.GET(CustLedgEntry2.“Closed by Entry No.”) THEN
UpdateDaysToPay(CustLedgEntry3.“Posting Date” - CustLedgEntry2.“Posting Date”);
END ELSE BEGIN
CustLedgEntry3.SETCURRENTKEY(“Closed by Entry No.”);
CustLedgEntry3.SETRANGE(“Closed by Entry No.”,CustLedgEntry2.“Entry No.”);
IF CustLedgEntry3.FIND(’+’) THEN
END;
IF NoOfInv <> 0 THEN
AvgDaysToPay[i] := DaysToPay / NoOfInv;
END;
END;
END;
CASE X OF
1,3: BEGIN
Amt := -CustLedgEntry[X].Amount;
RemAmt := -CustLedgEntry[X].“Remaining Amount”;
TotRemAmt := -TotalRemainAmountLCY[X];
END;
2,3,4,6 : BEGIN
Amt := CustLedgEntry[X].Amount;
RemAmt := CustLedgEntry[X].“Remaining Amount”;
END;
END;
END;
FIELDS
{ ; ;ExportText[X] }
{ ; ;CustLedgEntry[X].“Posting Date” }
{ ; ;CustLedgEntry[X].“Document No.” }
{ ; ;CustLedgEntry[X].“Currency Code” }
{ ; ;Amt }
{ ; ;RemAmt }
{ ; ;NoOfDoc[1][X] }
{ ; ;NoOfDoc[2][X] }
{ ; ;NoOfDoc[3][X] }
{ ; ;TotRemAmt }
REQUESTFORM
PROPERTIES
Width=9020;
Height=3410;
CONTROLS
CODE
VAR
CustLedgEntry2@1101353015 : Record 21;
CustLedgEntry3@1101353014 : Record 21;
DtldCustLedgEntry2@1101353013 : Record 379;
DateFilterCalc@1101353012 : Codeunit 358;
CustLedgEntry@1101353011 : ARRAY [6] OF Record 21;
CustDateFilter@1101353010 : ARRAY [3] OF Text[30];
CustDateName@1101353009 : ARRAY [3] OF Text[30];
TotalRemainAmountLCY@1101353008 : ARRAY [6] OF Decimal;
NoOfDoc@1101353007 : ARRAY [3,6] OF Integer;
AvgDaysToPay@1101353006 : ARRAY [3] OF Decimal;
DaysToPay@1101353005 : Decimal;
NoOfInv@1101353004 : Integer;
HighestBalanceLCY@1101353003 : ARRAY [3] OF Decimal;
CustBalanceLCY@1101353002 : Decimal;
i@1101353001 : Integer;
j@1101353000 : Integer;
Customer@1101353016 : Record 18;
ExportText@1101353017 : ARRAY [6] OF Text[30];
X@1101353018 : Integer;
“//ExpFields”@1101353022 : Integer;
Amt@1101353019 : Decimal;
RemAmt@1101353020 : Decimal;
TotRemAmt@1101353021 : Decimal;
LOCAL PROCEDURE
Hey Kevin,
Just wanted to see if the code I posted worked for you or not?
/TH
