Integration between Ax2012 and Dynamics CRM Connector error
Hi Friends,
Good day.
My requirement is to synch the data from Ax2012 to Dynamics CRM 2011 by using Connector. So we have done all the installation and standard services working fine. Now the customized tables also should synch with CRM. I have created the document service and inbound port also activated fine. when refreshing the service in Connector Ax2012 Adaptor setting it is throwing the exception called " An exception of type MetadataException has occurred while performing the Operation".
Can anyone pls help me to come out of this problem.
Advance thanks.
Abbas
Hi Abbas,
Did you get the solution for your issue? I am facing same problem but I dint get any solution.
Hi Parag,
That issue becoz of EDT relation not yet set properly which means incomplete. So better u check the table fields and its EDT s has been created properly or not.
I hope it will help your probs.
Abbas
But how to set this relation? I am doing fresh installtion on AX 2012 R2 with CU7 update…Can you please help me to resolve this issue.
Hi parag,
So if there is no customization then tell me which service you are trying to bring into connector?
Abbas
Hi Parag,
Please check the log file “C:\programdata\Microsoft Dynamics\Connector for Microsoft Dynamics\Logs”. In that you can find what errors are occurring.
Arif
Hi Abbas,
I am facing the same issue (below error) while configuring the connector after refreshing the services.(AX 2012 R3)
Error : Value cannot be null
Parameter name :type
Also can someone let me know how can I get a custom field in AX flow in the connector ,I have added the field in AX custtable and have refreshed the “DynamicsConnectorDefaultService” also ,but it is not showing up in the Configuration Maps.
Also on activating the map the records are not populating in the AX system.
Thanks and regards,
