Integration AX with Biztalk Server
Did any integrated AZ with Biztalk server 2006? Please help with the procedures of integration.
One way to do this is with the Microsoft Dynamics AX AIF BizTalk adapter.
A whitepaper describing how to use this can be found here: http://www.microsoft.com/downloads/details.aspx?FamilyID=FB4A979E-CCE1-4542-8188-4E8592031DA2&displaylang=en
I have done many data transformation projects using Dynamics Ax, SQL and BizTalk server without using AIF.
Essentially Ax exports/imports data to SQL Server. BizTalk reads data from SQL Server and converts the same into vendor’s required format and vice versa.
