Installing Outlook integration NAV2009
Hi Everyone,
One of our customers has asked me to setup a demo for the integration of NAV2009 SP1 with outlook.
After installing the (what I think are necessary) components, an error is given within NAV when starting the form Outlook Synch. Entities (classic client)
The error is: “Installation and configuration of the Microsoft Outlook Integration Add-in is not complete. Be sure that Outlook Integration is installed and all required objects are allowed to run”
I’ve installed the next components:
  • Role tailored Client
  • Server with Outlook integration
  • Classic Client with Outlook Integration
  • Application Server with Outlook Integration
  • SDK
  • Outlook add-in
The NAS connects to the demo SQL server database and is working with the startupparameter OSYNCH
The user I’m working with is in the user setup, a salesperson code has been created and its e-mail address is filled in. Also I’ve tried to insert a record in the table using the object designer. This seems to work, but when I try to open the Outlook Item, the same error is given.
I am working with Outlook 2003, with NAV2009 SP1 on SQL Server 2005 SP2.
Also I have done several de-installations and installations of the Outlook integration files to correct this error, but it does not seem to work.
As I am unable to see what should be installed more then I’ve done so far, does anyone has an idea of how to correct this?
Regards
Richard Jansen
Hello Richard,
There are so many pieces to that setup. Try this:
http://msdn.microsoft.com/en-us/library/dd338966.aspx
