Hi everyone I’am using AX 2009 installed on windows server 2008 R2, I’am trying to install Role Centers and Enterprise Portal so i followed the installation guide. after installing and configuring SharePoint Foundation 2010 and while installing Role Centers and Enterprise, setup has detected that i must install Microsoft windows SharePoint service 3.0 SP1 as a prerequisite but it gave me an error . i tried to install it manually but it gave me a massage “the update is already installed on the system” bellow is the setup log and its suggestion to remove Windows SharePoint Services 3.0. and then re install it again, but still nothing changed . === Setup logging started: 8/25/2016 11:34:10 AM === Running file: “C:\Users\ADMINI~1.domain\AppData\Local\Temp\2\AxSetup\AxSetup.exe” RelatedFilesDir=“C:\Users\administrator.domain\Desktop\DynamicsAX2009” AxSetup version number: 5.0.593.0 Microsoft Windows NT 6.1.7601 Service Pack 1 (64 bit) AX-REPORTS domain\administrator Interactive: True RelatedFilesDir=C:\Users\administrator.domain\Desktop\DynamicsAX2009 Property RelatedFilesDir set to: ‘C:\Users\administrator.domain\Desktop\DynamicsAX2009’ Property SetupLanguage set to: ‘EN’ === Loading parameters from the command line or a parameter file === Initializing log file: C:\ProgramData\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2016-08-25 11-34-10\DynamicsSetupLog.txt === Starting evaluation of existing installation state === MSI file: Components64.msi Installed: True MSI file: ClientHelp.msi Installed: True Property ClientHelpLanguages set to: ‘EN-US’ Previously Installed Component: Client Previously Installed Component: .NET Business Connector Property RunMode set to: ‘AddRemoveFeatures’ === Checking parameters === Property InstallPath set to: ‘C:\Program Files\Microsoft Dynamics AX\50’ Property InstallPath32Bit set to: ‘C:\Program Files (x86)\Microsoft Dynamics AX\50’ === Starting UI phase === Property RemoveComponents set to: ‘0’ Property BypassWarnings set to: ‘0’ Entering method GetBusinessConnectorProxyAccount The API return value is wnsc.sd\bcproxy. Leaving method GetBusinessConnectorProxyAccount Entering method IsRunningMode The API return value is True. Leaving method IsRunningMode Entering method IsUserAnAxAdmin The API return value is True. Leaving method IsUserAnAxAdmin Property InstallEnterprisePortal set to: ‘1’ Entering method IsRunningMode The API return value is True. Leaving method IsRunningMode Property WssSqlServer set to: ‘AX-DB1’ We do not recommend using your account domain\Administrator for the Windows SharePoint Services account. Contact your system administrator to create a dedicated account. Property WssAccount set to: ‘domain\Administrator’ Property WssAccountPassword set to: ‘’ Property WssPackagePath set to: ‘C:\Users\administrator.domain\Desktop\sharepoint\sharepointfoundation2010sp1-kb2460058-x64-fullfile-en-us.exe’ Configuring the .NET Framework ASP.Net for IIS C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet_regiis.exe -i -enable Microsoft (R) ASP.NET RegIIS version 4.0.30319.19215 Administration utility to install and uninstall ASP.NET on the local machine. Copyright (C) Microsoft Corporation. All rights reserved. Start installing ASP.NET (4.0.30319.19215). … Finished installing ASP.NET (4.0.30319.19215). C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet_regiis.exe -sn W3SVC Microsoft (R) ASP.NET RegIIS version 4.0.30319.19215 Administration utility to install and uninstall ASP.NET on the local machine. Copyright (C) Microsoft Corporation. All rights reserved. Start registering ASP.NET (4.0.30319.19215) at W3SVC. Finished registering ASP.NET (4.0.30319.19215) at W3SVC. Entering function ReadRegKey Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property AdminServerLocation Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0 with Attribute AdminServerLocation has value Leaving function ReadRegKey Microsoft Dynamics AX could not find the IIS metabase information for the SharePoint Central Administration page. Entering function ReadRegKey Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property version Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0 with Attribute version has value Leaving function ReadRegKey Entering function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.InstallSharepoint Entering function InstallSharepoint Setup invoked the InstallSharePoint API with the parameters: SharePointMsiPath:C:\Users\administrator.domain\Desktop\sharepoint\sharepointfoundation2010sp1-kb2460058-x64-fullfile-en-us.exe, SqlServer:AX-DB1, SqlServerAccount:domain\Administrator Entering function IsSharePoint2Installed Entering function ReadRegKey Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0, property version Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0 with Attribute version has value Leaving function ReadRegKey Entering function IsWSS30SetupUsed Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property Location Entering function ExecuteProcess Entering function RemovePassword Leaving function RemovePassword Process C:\Users\administrator.domain\Desktop\sharepoint\sharepointfoundation2010sp1-kb2460058-x64-fullfile-en-us.exe executed with arguments /extract:“C:\Users\administrator.domain\AppData\Local\Temp\2\EnterprisePortalSetup” /quiet. Entering function RemovePassword Leaving function RemovePassword Process C:\Users\administrator.domain\Desktop\sharepoint\sharepointfoundation2010sp1-kb2460058-x64-fullfile-en-us.exe executed sucessfully with argument /extract:“C:\Users\administrator.domain\AppData\Local\Temp\2\EnterprisePortalSetup” /quiet. Leaving function ExecuteProcess Setup could not find file C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup\Files\SetupFarmSilent\config.xml. It does not exist. Microsoft.Dynamics.Framework.Deployment.Portal.EPDeploymentException at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.InstallSharepoint(String sharepointMsiPath, String sqlServer, String sqlServerAccount, String sqlServerAccountPassword) Entering function DeleteSingleFolderFromDisk Deleting folder C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup Leaving function DeleteSingleFolderFromDisk Setup could not find file C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup\Files\SetupFarmSilent\config.xml. It does not exist. An error occurred during installation of Windows Sharepoint Services. Property BypassWarnings set to: ‘0’ Entering method IsRunningMode The API return value is True. Leaving method IsRunningMode Property WssSqlServer set to: ‘AX-DB1’ We do not recommend using your account WNSC\Administrator for the Windows SharePoint Services account. Contact your system administrator to create a dedicated account. Property WssAccount set to: ‘WNSC\Administrator’ Property WssAccountPassword set to: '’ Property WssPackagePath set to: ‘C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe’ Entering function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.InstallSharepoint Entering function InstallSharepoint Setup invoked the InstallSharePoint API with the parameters: SharePointMsiPath:C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe, SqlServer:AX-DB1, SqlServerAccount:WNSC\Administrator Entering function IsSharePoint2Installed Entering function ReadRegKey Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0, property version Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0 with Attribute version has value Leaving function ReadRegKey Entering function IsWSS30SetupUsed Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property Location Entering function ExecuteProcess Entering function RemovePassword Leaving function RemovePassword Process C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe executed with arguments /extract:“C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup” /quiet. Entering function RemovePassword Leaving function RemovePassword Process C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe executed sucessfully with argument /extract:“C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup” /quiet. Leaving function ExecuteProcess Setup could not find file C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup\Files\SetupFarmSilent\config.xml. It does not exist. Microsoft.Dynamics.Framework.Deployment.Portal.EPDeploymentException at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.InstallSharepoint(String sharepointMsiPath, String sqlServer, String sqlServerAccount, String sqlServerAccountPassword) Entering function DeleteSingleFolderFromDisk Deleting folder C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup Leaving function DeleteSingleFolderFromDisk Setup could not find file C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup\Files\SetupFarmSilent\config.xml. It does not exist. An error occurred during installation of Windows Sharepoint Services. Property BypassWarnings set to: ‘0’ Entering method IsRunningMode The API return value is True. Leaving method IsRunningMode Property WssSqlServer set to: ‘AX-DB1’ We do not recommend using your account WNSC\Administrator for the Windows SharePoint Services account. Contact your system administrator to create a dedicated account. Property WssAccount set to: ‘WNSC\Administrator’ Property WssAccountPassword set to: ‘’ Property WssPackagePath set to: ‘C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe’ Entering function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.InstallSharepoint Entering function InstallSharepoint Setup invoked the InstallSharePoint API with the parameters: SharePointMsiPath:C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe, SqlServer:AX-DB1, SqlServerAccount:WNSC\Administrator Entering function IsSharePoint2Installed Entering function ReadRegKey Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0, property version Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0 with Attribute version has value Leaving function ReadRegKey Entering function IsWSS30SetupUsed Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property Location Leaving function IsWSS30SetupUsed Windows SharePoint Services 3.0 has been partially installed. Use Add and Remove Programs to remove Windows SharePoint Services 3.0, and then run Microsoft Dynamics AX Setup again to reinstall Windows SharePoint Services 3.0. Microsoft.Dynamics.Framework.Deployment.Portal.EPDeploymentException at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.InstallSharepoint(String sharepointMsiPath, String sqlServer, String sqlServerAccount, String sqlServerAccountPassword) Windows SharePoint Services 3.0 has been partially installed. Use Add and Remove Programs to remove Windows SharePoint Services 3.0, and then run Microsoft Dynamics AX Setup again to reinstall Windows SharePoint Services 3.0. An error occurred during installation of Windows Sharepoint Services. Property BypassWarnings set to: ‘0’ Property InstallDebugger set to: ‘1’ Entering method IsRunningMode The API return value is True. Leaving method IsRunningMode Property BypassWarnings set to: ‘0’ Property InstallDebugger set to: ‘0’ Entering method IsRunningMode The API return value is True. Leaving method IsRunningMode Property WssSqlServer set to: ‘AX-DB1’ We do not recommend using your account WNSC\Administrator for the Windows SharePoint Services account. Contact your system administrator to create a dedicated account. Property WssAccount set to: ‘WNSC\Administrator’ Property WssAccountPassword set to: '’ Property WssPackagePath set to: ‘C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe’ Entering function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.InstallSharepoint Entering function InstallSharepoint Setup invoked the InstallSharePoint API with the parameters: SharePointMsiPath:C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe, SqlServer:AX-DB1, SqlServerAccount:WNSC\Administrator Entering function IsSharePoint2Installed Entering function ReadRegKey Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0, property version Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0 with Attribute version has value Leaving function ReadRegKey Entering function IsWSS30SetupUsed Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property Location Leaving function IsWSS30SetupUsed Windows SharePoint Services 3.0 has been partially installed. Use Add and Remove Programs to remove Windows SharePoint Services 3.0, and then run Microsoft Dynamics AX Setup again to reinstall Windows SharePoint Services 3.0. Microsoft.Dynamics.Framework.Deployment.Portal.EPDeploymentException at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.InstallSharepoint(String sharepointMsiPath, String sqlServer, String sqlServerAccount, String sqlServerAccountPassword) Windows SharePoint Services 3.0 has been partially installed. Use Add and Remove Programs to remove Windows SharePoint Services 3.0, and then run Microsoft Dynamics AX Setup again to reinstall Windows SharePoint Services 3.0. An error occurred during installation of Windows Sharepoint Services. === Setup logging started: 8/25/2016 11:34:10 AM === Running file: “C:\Users\ADMINI~1.WNS\AppData\Local\Temp\2\AxSetup\AxSetup.exe” RelatedFilesDir=“C:\Users\administrator.WNSC\Desktop\DynamicsAX2009” AxSetup version number: 5.0.593.0 Microsoft Windows NT 6.1.7601 Service Pack 1 (64 bit) AX-REPORTS WNSC\administrator Interactive: True RelatedFilesDir=C:\Users\administrator.WNSC\Desktop\DynamicsAX2009 Property RelatedFilesDir set to: ‘C:\Users\administrator.WNSC\Desktop\DynamicsAX2009’ Property SetupLanguage set to: ‘EN’ === Loading parameters from the command line or a parameter file === Initializing log file: C:\ProgramData\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2016-08-25 11-34-10\DynamicsSetupLog.txt === Starting evaluation of existing installation state === MSI file: Components64.msi Installed: True MSI file: ClientHelp.msi Installed: True Property ClientHelpLanguages set to: ‘EN-US’ Previously Installed Component: Client Previously Installed Component: .NET Business Connector Property RunMode set to: ‘AddRemoveFeatures’ === Checking parameters === Property InstallPath set to: ‘C:\Program Files\Microsoft Dynamics AX\50’ Property InstallPath32Bit set to: ‘C:\Program Files (x86)\Microsoft Dynamics AX\50’ === Starting UI phase === Property RemoveComponents set to: ‘0’ Property BypassWarnings set to: ‘0’ Entering method GetBusinessConnectorProxyAccount The API return value is wnsc.sd\bcproxy. Leaving method GetBusinessConnectorProxyAccount Entering method IsRunningMode The API return value is True. Leaving method IsRunningMode Entering method IsUserAnAxAdmin The API return value is True. Leaving method IsUserAnAxAdmin Property InstallEnterprisePortal set to: ‘1’ Entering method IsRunningMode The API return value is True. Leaving method IsRunningMode Property WssSqlServer set to: ‘AX-DB1’ We do not recommend using your account WNSC\Administrator for the Windows SharePoint Services account. Contact your system administrator to create a dedicated account. Property WssAccount set to: ‘WNSC\Administrator’ Property WssAccountPassword set to: ‘’ Property WssPackagePath set to: ‘C:\Users\administrator.WNSC\Desktop\sharepoint\sharepointfoundation2010sp1-kb2460058-x64-fullfile-en-us.exe’ Configuring the .NET Framework ASP.Net for IIS C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet_regiis.exe -i -enable Microsoft (R) ASP.NET RegIIS version 4.0.30319.19215 Administration utility to install and uninstall ASP.NET on the local machine. Copyright (C) Microsoft Corporation. All rights reserved. Start installing ASP.NET (4.0.30319.19215). … Finished installing ASP.NET (4.0.30319.19215). C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet_regiis.exe -sn W3SVC Microsoft (R) ASP.NET RegIIS version 4.0.30319.19215 Administration utility to install and uninstall ASP.NET on the local machine. Copyright (C) Microsoft Corporation. All rights reserved. Start registering ASP.NET (4.0.30319.19215) at W3SVC. Finished registering ASP.NET (4.0.30319.19215) at W3SVC. Entering function ReadRegKey Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property AdminServerLocation Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0 with Attribute AdminServerLocation has value Leaving function ReadRegKey Microsoft Dynamics AX could not find the IIS metabase information for the SharePoint Central Administration page. Entering function ReadRegKey Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property version Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0 with Attribute version has value Leaving function ReadRegKey Entering function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.InstallSharepoint Entering function InstallSharepoint Setup invoked the InstallSharePoint API with the parameters: SharePointMsiPath:C:\Users\administrator.WNSC\Desktop\sharepoint\sharepointfoundation2010sp1-kb2460058-x64-fullfile-en-us.exe, SqlServer:AX-DB1, SqlServerAccount:WNSC\Administrator Entering function IsSharePoint2Installed Entering function ReadRegKey Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0, property version Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0 with Attribute version has value Leaving function ReadRegKey Entering function IsWSS30SetupUsed Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property Location Entering function ExecuteProcess Entering function RemovePassword Leaving function RemovePassword Process C:\Users\administrator.WNSC\Desktop\sharepoint\sharepointfoundation2010sp1-kb2460058-x64-fullfile-en-us.exe executed with arguments /extract:“C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup” /quiet. Entering function RemovePassword Leaving function RemovePassword Process C:\Users\administrator.WNSC\Desktop\sharepoint\sharepointfoundation2010sp1-kb2460058-x64-fullfile-en-us.exe executed sucessfully with argument /extract:“C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup” /quiet. Leaving function ExecuteProcess Setup could not find file C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup\Files\SetupFarmSilent\config.xml. It does not exist. Microsoft.Dynamics.Framework.Deployment.Portal.EPDeploymentException at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.InstallSharepoint(String sharepointMsiPath, String sqlServer, String sqlServerAccount, String sqlServerAccountPassword) Entering function DeleteSingleFolderFromDisk Deleting folder C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup Leaving function DeleteSingleFolderFromDisk Setup could not find file C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup\Files\SetupFarmSilent\config.xml. It does not exist. An error occurred during installation of Windows Sharepoint Services. Property BypassWarnings set to: ‘0’ Entering method IsRunningMode The API return value is True. Leaving method IsRunningMode Property WssSqlServer set to: ‘AX-DB1’ We do not recommend using your account WNSC\Administrator for the Windows SharePoint Services account. Contact your system administrator to create a dedicated account. Property WssAccount set to: ‘WNSC\Administrator’ Property WssAccountPassword set to: '’ Property WssPackagePath set to: ‘C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe’ Entering function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.InstallSharepoint Entering function InstallSharepoint Setup invoked the InstallSharePoint API with the parameters: SharePointMsiPath:C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe, SqlServer:AX-DB1, SqlServerAccount:WNSC\Administrator Entering function IsSharePoint2Installed Entering function ReadRegKey Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0, property version Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0 with Attribute version has value Leaving function ReadRegKey Entering function IsWSS30SetupUsed Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property Location Entering function ExecuteProcess Entering function RemovePassword Leaving function RemovePassword Process C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe executed with arguments /extract:“C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup” /quiet. Entering function RemovePassword Leaving function RemovePassword Process C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe executed sucessfully with argument /extract:“C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup” /quiet. Leaving function ExecuteProcess Setup could not find file C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup\Files\SetupFarmSilent\config.xml. It does not exist. Microsoft.Dynamics.Framework.Deployment.Portal.EPDeploymentException at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.InstallSharepoint(String sharepointMsiPath, String sqlServer, String sqlServerAccount, String sqlServerAccountPassword) Entering function DeleteSingleFolderFromDisk Deleting folder C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup Leaving function DeleteSingleFolderFromDisk Setup could not find file C:\Users\administrator.WNSC\AppData\Local\Temp\2\EnterprisePortalSetup\Files\SetupFarmSilent\config.xml. It does not exist. An error occurred during installation of Windows Sharepoint Services. Property BypassWarnings set to: ‘0’ Entering method IsRunningMode The API return value is True. Leaving method IsRunningMode Property WssSqlServer set to: ‘AX-DB1’ We do not recommend using your account WNSC\Administrator for the Windows SharePoint Services account. Contact your system administrator to create a dedicated account. Property WssAccount set to: ‘WNSC\Administrator’ Property WssAccountPassword set to: ‘’ Property WssPackagePath set to: ‘C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe’ Entering function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.InstallSharepoint Entering function InstallSharepoint Setup invoked the InstallSharePoint API with the parameters: SharePointMsiPath:C:\Users\administrator.WNSC\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe, SqlServer:AX-DB1, SqlServerAccount:WNSC\Administrator Entering function IsSharePoint2Installed Entering function ReadRegKey Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0, property version Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0 with Attribute version has value Leaving function ReadRegKey Entering function IsWSS30SetupUsed Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property Location Leaving function IsWSS30SetupUsed Windows SharePoint Services 3.0 has been partially installed. Use Add and Remove Programs to remove Windows SharePoint Services 3.0, and then run Microsoft Dynamics AX Setup again to reinstall Windows SharePoint Services 3.0. Microsoft.Dynamics.Framework.Deployment.Portal.EPDeploymentException at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.InstallSharepoint(String sharepointMsiPath, String sqlServer, String sqlServerAccount, String sqlServerAccountPassword) Windows SharePoint Services 3.0 has been partially installed. Use Add and Remove Programs to remove Windows SharePoint Services 3.0, and then run Microsoft Dynamics AX Setup again to reinstall Windows SharePoint Services 3.0. An error occurred during installation of Windows Sharepoint Services. Property BypassWarnings set to: ‘0’ Property InstallDebugger set to: ‘1’ Entering method IsRunningMode The API return value is True. Leaving method IsRunningMode Property BypassWarnings set to: ‘0’ Property InstallDebugger set to: ‘0’ Entering method IsRunningMode The API return value is True. Leaving method IsRunningMode Property WssSqlServer set to: ‘AX-DB1’ We do not recommend using your account domain\Administrator for the Windows SharePoint Services account. Contact your system administrator to create a dedicated account. Property WssAccount set to: ‘domain\Administrator’ Property WssAccountPassword set to: '’ Property WssPackagePath set to: ‘C:\Users\administrator.domain\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe’ Entering function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.InstallSharepoint Entering function InstallSharepoint Setup invoked the InstallSharePoint API with the parameters: SharePointMsiPath:C:\Users\administrator.domain\Desktop\sharepoint\wssv3sp1-kb936988-x64-fullfile-en-us.exe, SqlServer:AX-DB1, SqlServerAccount:domain\Administrator Entering function IsSharePoint2Installed Entering function ReadRegKey Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0, property version Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\6.0 with Attribute version has value Leaving function ReadRegKey Entering function IsWSS30SetupUsed Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property Location Leaving function IsWSS30SetupUsed Windows SharePoint Services 3.0 has been partially installed. Use Add and Remove Programs to remove Windows SharePoint Services 3.0, and then run Microsoft Dynamics AX Setup again to reinstall Windows SharePoint Services 3.0. Microsoft.Dynamics.Framework.Deployment.Portal.EPDeploymentException at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.InstallSharepoint(String sharepointMsiPath, String sqlServer, String sqlServerAccount, String sqlServerAccountPassword) Windows SharePoint Services 3.0 has been partially installed. Use Add and Remove Programs to remove Windows SharePoint Services 3.0, and then run Microsoft Dynamics AX Setup again to reinstall Windows SharePoint Services 3.0. An error occurred during installation of Windows Sharepoint Services. Thank you.
