Installation of Dynamics 365: Registry key not found error
I am getting below error when trying to install D365BC, any help suggestion to get rid of this error.
Id = ‘IISASPNET45Installed’, Registry value not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’, Value = ‘ASPNET45’
RegistrySearch: Id = ‘IISNETFXInstalled’, searching for registry key value.
Id = ‘IISNETFXInstalled’, Registry value not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’, Value = ‘NetFxExtensibility’
RegistrySearch: Id = ‘IISNETFX45Installed’, searching for registry key value.
Id = ‘IISNETFX45Installed’, Registry value not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’, Value = ‘NetFxExtensibility45’
RegistrySearch: Id = ‘IISISAPEXInstalled’, searching for registry key value.
Id = ‘IISISAPEXInstalled’, Registry value not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’, Value = ‘ISAPIExtensions’
RegistrySearch: Id = ‘HttpActivationInstalled’, checking registry key existence.
Id = ‘HttpActivationInstalled’, Key = ‘SYSTEM\CurrentControlSet\Services\WAS’, Exists = ‘0’
RegistrySearch: Id = ‘IISISAPIFIInstalled’, searching for registry key value.
Id = ‘IISISAPIFIInstalled’, Registry value not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’, Value = ‘ISAPIFilter’
RegistrySearch: Id = ‘IISREQSTFIInstalled’, searching for registry key value.
Id = ‘IISREQSTFIInstalled’, Registry value not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’, Value = ‘RequestFiltering’
RegistrySearch: Id = ‘IISSTATICInstalled’, searching for registry key value.
Id = ‘IISSTATICInstalled’, Registry value not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’, Value = ‘StaticContent’
RegistrySearch: Id = ‘WebComponentsPrerequisitesInstalled’, searching for registry key value.
Id = ‘WebComponentsPrerequisitesInstalled’, Registry key not found. Key = ‘SOFTWARE\Microsoft\Microsoft Dynamics NAV\140\Web Components Prerequisites’
RegistrySearch: Id = ‘IdentityFoundationInstalled’, checking registry key existence.
Id = ‘IdentityFoundationInstalled’, Key = ‘SOFTWARE\Microsoft\Windows Identity Foundation\Setup\v3.5’, Exists = ‘1’
RegistrySearch: Id = ‘IISAspNetCoreModuleInstalled’, searching for registry key value.
Id = ‘IISAspNetCoreModuleInstalled’, Registry key not found. Key = ‘SOFTWARE\Microsoft\IIS Extensions\IIS AspNetCore Module’
Configuring package. Id = ‘ARP’
MSI log file set to: C:\Users\evs\AppData\Local\Temp\setup.wix.msi.15.log
Done configuring package. Id = ‘ARP’ ReturnCode = 0
Configuring package. Id = ‘DotNetFx472’
