I have just installed the server and is about to start the client - but then I experience a problem. The server cant find the database i the folder that was specified. The database is there and it is possible to open it as a local database. There is no writeprotection. Is there anyone who can tell me what the problem is?
Did you use the default options while installing both client and database? What is the exact error message you are getting?
The v4.0 Navision Server service is installed to run under the ‘Network Service’ builtin account (previous versions ran under the ‘Local System’ account). Since the ‘Network Service’ account is expected to run services that expose the machine to network, this account is given almost no access to local machine resources. You must grant the ‘Network Service’ account read/write permissions to the database files before the service can run. For more info, see the ‘Hardening Guide for Navision 4.0’ available on PartnerSource/PartnerGuide…
