I am able to create object for COM dll registered in my system.
However, currently i am trying to use ‘LpiCom_6_0.dll’ i.e. payment gateway DLL from First Data. On create of this, it gives me following message,
Microsoft Dynamics NAV Classic
This message is for C/AL programmers:
Could not create an instance of the OLE control or Automation server identified by
GUID={1C0876A6-FF84-48E6-95BE-D3F21C883D14} 1.0:{E973A9DF-8CC6-4A66-802B-39703FD0620B}:‘LpiCom_6_0 1.0 Type Library’.LinkPointTxn.
Check that the OLE control or Automation server is correctly installed and registered.
However, i am able to use the same registered DLL from my other classic ASP version as well as .Net based application. But, this does not seems to be working with NAV 2009.
I have the same issue. Were you able to solve this? They have an alternative to using the dll which is to call the web service. The dll does not work on 64 bit environment. This dll worked on navision 3.7 for me though.
