Indian Payroll
HI Is there any updates to the HR Vertical?If so, where can it be got from?. There are few queries as to why in the PayrollLoan master, a field called “Loan type” is hidden in the form.however, in the code, they have used it,. This has an option of “advance”.Y not use this to deduct advances and why should the advance deduction be configured as a loan? If somebody could tell where proper documentation for this module is available it would be of great help. thanx
Are you talking of attain (navision) or axapta Rg Anuj
Hi, Documentation is available and you can download from the partner site or the FTP site. As regards usage of the Loan field towards advances,Functionally also an advance is a Short Term Loan only which is recovered on some different terms and conditions. So, If you need that description, You can still use the filed with its’ name changed on a form.Define a Loan TYpe as AdvaNCE. This is simpler than writing a separate code for the Advances. Regards, DD
