Increase Margin Width in Morphx Report Ax 4.0
Hi ,
I want to increase the width of Report margin … can any one suggest answer…My screen Shot is attached below.
Have you checked the Right Margin property on the report design?
yeah but it doesnot move
Is that a standard report? If so what is the report name?
No its customized report …But i need to know how to move a margin in Report .you can take any report like “SalesQuotation” Report … Only thing is want to move a margin in Report…
Then right margin property should work.
Hi kranthi ,
when i increase the increase in right margin the Highlighted points only incresed not in Report size…When i Run Report there is no changes.The Screen Shot is attached below kindly check.
Hi Kranthi,
See the design property screen shot too…
It could be due to the combination of other two property values (Orientation and FitToPage). Try by changing the FitToPage property to Yes.
Hi Kranthi,
When i give like that size would reduced small
Then how about changing the Orientation to landscape/Auto?
