Hi David,
That is default behavior of NAV. So if it doesn’t work for you, then I’m sure it must be something in LS Retail, then I’m sure it must be LSR that is doing it. Could you eventually, just for testing, try to create a normal NAV invoice, and see how it calculates the discount here.
David are you in the middle east? If so there are a lot of issues with the new VAT rules introduced on Jan 1st. NAV and LS retail (at least the version we had last year) does not correctly work with the new VAT rules in Dubai, (where I am). And its not just the rate calculation that is wrong, it also has issues with the geographic locations.
I am not sure if LS Retail have addressed this yet. I have approached a number of NAV / LS customers, and most are simply waiting it out till the first round of VAT submissions happen in June. And hoping that the tax authority wont implement the fines. IN Dubai the mistake you describe above has about a $1,200 fine PER sales document printed.
Yes…I am in middle east - Bahrain. And currently we are implementing VAT for Saudi based client. Even VAT Consultants are not clear with the rules proposed by Saudi government.
So we are trying to customize LS code for VAT calculation. [emoticon:f46987a61e1246c8aea1dabe4dc68d98]
Same here in Dubai. The Tax authority quite smartly have already extended filing dates by 2 months to give people time to try and figure it all out. The question is whether they will enforce fines and penalties, because I have already seen millions of dollars of potential fines due to VAT errors in retail here.
I think you need to go in and customize the code to follow the laws as I don’t thing it makes sense to wait for LS Retail to fix this.
