hi ,
when i trying to run the report form the menuitem output , i am facing the error
remote server returned an error :500
please help me if any body know this .
thanks,
srikanth
hi ,
thanks,
srikanth
Hi Srikanth,
Please can you provide following info -
Few of the user facing the same error when generating report.
Below is the error details :-
Log Name: Application
Source: Microsoft.Dynamics.AX.Frameworks.Controls
Date: 2/25/2013 5:31:50 PM
Event ID: 1000
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: aos01.dpo.local
Description:
The remote server returned an error: (500) Internal Server Error.
Microsoft.Reporting.WinForms.ReportServerException
at Microsoft.Reporting.WinForms.ServerReport.ServerUrlRequest(Boolean isAbortable, String url, Stream outputStream, String& mimeType, String& fileNameExtension)
at Microsoft.Reporting.WinForms.ServerReport.InternalRender(Boolean isAbortable, String format, String deviceInfo, NameValueCollection urlAccessParameters, Stream reportStream, String& mimeType, String& fileNameExtension)
at Microsoft.Reporting.WinForms.AsyncMainStreamRenderingOperation.RenderServerReport(ServerReport report)
at Microsoft.Reporting.WinForms.AsyncRenderingOperation.PerformOperation()
at Microsoft.Reporting.WinForms.ReportViewer.AsyncReportOperationWrapper.PerformOperation()
at Microsoft.Reporting.WinForms.ProcessingThread.ProcessThreadMain(Object arg)
System.Net.WebException
at System.Net.HttpWebRequest.GetResponse()
Event Xml:
1000
2
0
0x80000000000000
184248
Application
aos01.dpo.local
Hi Choy,
I got same issue when i am run SSRS report, could you please advise me if you have fixed, My email id: ravindarreddyd@yahoo.com , It’s bit urgent thanks
Hi Srikanth,
I have same issue, It’s giving pain in my ass hole mate, could you please me how you have fixed this error. please
Thanks and Regards,
Ravindar Reddy. Dasari
hi ,
restart the reporting services…???
Hi Mate,
Thank you very much for your earlier reply, i have restated services but no luck
Ravi
do one thing , system administration module ,setup ,service and application intergation framework , in bound port , bi service stop the services and restart the services. and restart the reporting services
and run the report.
