In ax 2009, while pulling any reports, we have the option to filter our query , like providing ranges.
Like inside dialog-Select Button-Inside which we can set a range as in PFA-.
I understand that its user specific , so that whenever he pulls the report based on the range whichever is defined.
I am interested to know where this values gets stored in database??
Reason: I had a custom reciept report which was directly connected to printer and its was picking “jounal number” from ledgerjournal Table but later , i changed the logic to pick it from ledgerjournaltrans and the outpit of report was really “shocking”-an output without meaning, complete values went wrong.
For this , when i changed the client configuration, like i create a new client configuration and ran the report-the result was perfect,
i still wonder whats the reason and would like to know whetehr it have anything to do with the previuosly saved ranges in old configuration??
As in PFA- Where the Journal number range provided gets stored.
The Usage data functionality stores information such as ranges, report selections etc. The underlying data gets stored in ‘SysLastValue’ table. You should be able to verify this by running following SQL statement -
while select SysLastValue
where SysLastValue.userId == ‘HARISH’
&& SysLastValue.company == curext()
&& SysLastValue.recordType == UtilElementType::UserSetupQuery
The values get stored in the ‘Value’ field in ‘SysLastValue’ which is a container.
You can also use ‘xSysLastValue’ framework to extract the value. You can see example of how to call this framework in many standard AX forms such as ProjTable (init method) and classes such as PurchTableForm (new method).
Harish is right, it’s stored in SysLastValue table. Are you aware of that Value is a container field and you won’t see its content in grid? You have to open its lookup to see the tree of values stored in the container.
