Check out Report 81 - import budget from Excel. The Excel Buffer table knows how to read an Excel sheet into that table. From there you will have to analyze and process the data yourself.
Instead of using a dataport to import from an Excel file I’m trying to use a report. The data in the Excel file are first imported to the Excel Buffer table and from there to the Item and Item Vendor tables. When I check the Item and Item Vendor tables the data haven’t been imported.
What could be the problem? The Excel file or something else?
As you don’t get any error message, there is something “missing” or not working in your code. Are you sure you insert your item record created from the ExcelBuffer?
I have tried the message function to return inserted values from excel buffer, it seems you’re right, nothing seems to have been inserted from the excel file into excel buffer.
But still a dialog box appears, showing something like ‘100%’, indicating that the excel file is actually being read. However, it seems the values in the file are not inserted into excel buffer.
What could be the problem? The file to be imported is an xls file.
An XLS file cannot be imported directly because this file format is not supported by NAV.
A possibility to import the data from the XLS file would be to convert it to a format which is supported by NAV, for example to CSV format (this could be easily done by saving the file from exel and specifying the format CSV). After that you could import the CSV file with a “simple” dataport.
Annother possibility would be the direct import from excel as an automation server… - but I think you should prefer the first method.
An xls file CAN be import directly into Navision by using the read sheet function in the excel buffer.
Have you tried using the Excel Buffer not as a tempory table and seeing if it is populated?
My coding adapted so that it can run under NAS (no window!)
IF NOT CREATE(xlapp,TRUE) THEN;
xlapp.Workbooks.Open(FileName);
xlwrkbk := xlapp.ActiveWorkbook;
i := 1;
EndOfLoop := xlwrkbk.Worksheets.Count;
WHILE (i <= EndOfLoop) AND (NOT Found) DO BEGIN
xlwrkshts := xlwrkbk.Worksheets.Item(i);
IF SheetName = xlwrkshts.Name THEN
Found := TRUE;
i := i + 1;
END;
IF Found THEN
xlwrksht := xlwrkbk.Worksheets.Item(SheetName)
ELSE BEGIN
xlwrkbk.Close(FALSE);
xlapp.Quit;
CLEAR(xlapp);
ERROR(Text004,SheetName);
END;
xlrange := xlwrksht.Range(ExcelBuf.GetExcelReference(5)).SpecialCells(11);
maxi := xlrange.Row;
maxj := xlrange.Column;
i := 1;
REPEAT
j := 1;
ExcelBuf.VALIDATE(“Row No.”,i);
REPEAT
ExcelBuf.VALIDATE(“Column No.”,j);
ExcelBuf.“Cell Value as Text” := DELCHR(FORMAT(xlwrksht.Range(ExcelBuf.xlColID + ExcelBuf.xlRowID).Value),’<’,’ ');
IF ExcelBuf.“Cell Value as Text” <> ‘’ THEN BEGIN
ExcelBuf.INSERT;
END;
j := j + 1;
UNTIL j > maxj;
i := i + 1;
UNTIL i > maxi;
xlapp.Quit;
CLEAR(xlapp);
Thanks for your help and patience! The problem has been solved. I’ve imported an xls excel file using a report based on the “Excel Buffer” table. NAV by default added a 1000 separator to some of the figures I tried to import, that’s why I had problems importing the file. I’ll soon post you a detailed description on how to correct this kind of problem.
