do{
ttsbegin;
row++;
NumberSeq = NumberSeq::newGetNumFromCode(BOMParameters::numRefBOMId().numberSequence);
bom.BOMId=NumberSeq.num();
bom.Name=cells.item(row,1).value().bStr();
bom.ItemGroupId=cells.item(row,2).value().bStr();
bom.SiteId=cells.item(row,3).value().bStr();
bom.insert();
type= cells.item(row+1,1).value().variantType();
ttscommit;
I’m trying to import the value into ax BOMTable, all the values got inserted except the siteId…
I checked the relations to, shall I know how to insert it from excel?
Thanks.
              probably cell’s value is numeric and your code reads empty string. you may use my method for read guarantee sited cell:
bom.siteid = getcellfromexcel(cells.item(row,3));
put this method to global class and change your code like up:
public static str getCellfromExcel(SysExcelCell _cell)
Name name;
real r;
switch(_cell.value().variantType())
case COMVariantType::VT_BSTR:
name = _cell.value().bStr();
break;
case COMVariantType::VT_DECIMAL, COMVariantType::VT_R4, COMVariantType::VT_R8:
r = _cell.value().double();
if (real2int(r) == r)
name = num2str(r,0,0,1,0);
else
name = num2str(r,0,5,1,0);
break;
case COMVariantType::VT_I1, COMVariantType::VT_I2, COMVariantType::VT_I4:
name = num2str(_cell.value().int(),0,0,0,0);
break;
case COMVariantType::VT_UI1, COMVariantType::VT_UI2, COMVariantType::VT_UI4:
name = num2str(_cell.value().uLong(),0,0,0,0);
break;
case (COMVariantType::VT_DATE):
name = date2str(_cell.value().date(),123,2,1,2,1,4);
case COMVariantType::VT_EMPTY:
name ="";
break;
default:
name="";
return name;
              and don’t forget to clear left blank space!!!
