W e have uploaded the standard cost through template (inventitempricesim), data has been imported successfully into the table however same is into showing in the costing version >> pending price form
Kindly request you to let us know why it is not showing on the form and do the needful at the earliest
The issue is clearly with your import, please review what it is doing and ensure you understand the processing differences of pending and active and any relations involved in the activation process if your end aim is to have active prices post import.
you are right, we suppose to be mentioned the invent dim id in the template >> dimension no field but i have mentioned site in the same column this is the reason for the issue
Now i want to know which invent dime id i have to mention in the template as there are so many dimid’s is there for this site
Kindly let us know which dimid i have to select and do the needful at the earliest
The items prices can be defined per site and/or per product dimensions, you need to consider the dimension with only site or a combination of site and product dimension(if it is a product master).
