import XML in NF 2.60
Hello I have a xml structure. I will import it in a NAVISION table. what for method can i use to do that. Can anybody explain that. Sorry for my englich Thank you very match for your help Didier
Hi This is very very easy, Use the MSXML automation object (search microsoft.com for the download if you do not have it) See http://www.navision.net/forum/topic.asp?TOPIC_ID=976&FORUM_ID=18&CAT_ID=3 Which gives an example of what you are trying to do. Paul Baxter
