Hi everyone
Please tell me how to import sales order in ax 2009. I have 100 sales order but im facing the problem while import the sales order. If there is any script for importing data in axapta. Please mail me mggoswami@gmail.com
Thanks in advance
from
Mohan
hi
sales Orders may not import directly …
you need to write code for that to create and post the orders …(becuz …number sequence problem)
if anyone knows importing SO’s using excel sheets give the way to import that
ax_cons
September 17, 2012, 4:37pm
3
Ramesh is right… You can import the sales table and sales line data in a staging table and from there you can create SO using jobs.
I think that will be simpler. You need to check which all classes are hit and use the same logic for SO creation.
Rather than asking for code, you should give a try and post the problems which you face. That will help you only.
Pranav…
