Import File Window _ AX 2012
Hi everyone,
Could anyone please explain, What is the use of “Delete sub-elements” and “Enable data recovery for table with changed IDs” controls in Import form.
Siva
I’m looking for the answer on this, any help will be appreciated.
It would delete the subelements of the objects(for instance a method in forms node) that are not in the xpo file
So if I wont check that delete sub-element it will append new methods and leave the old one there?
