Hello,
i want to create a demon environment with AX2012R3 and there’s no functional link of Import Data Demo Tool.
Can anyone give me a functional link to download it?
Thanks.
Hello,
Thanks.
Hi Bogdan,
Please see the below links:
http://technet.microsoft.com/en-us/library/dn756356.aspx
http://tech.alirazazaidi.com/how-to-import-contoso-demo-data-to-dynamics-ax-2012-r3/
Hi Ishak,
thank you for your answer but i,e visited the two links several times with no luck.
Both of them are pointing to https://informationsource.dynamics.com/RFPServicesOnline/RfpServicesOnline.aspx and then https://lcs.dynamics.com/ where there is no download link.
i’m moving in circle following the procedures.
Please check in Dynamics Life Cycle Services. You should have the access on LCS/Customer Source to download the link.
https://lcs.dynamics.com/Logon/Index?redirectUrl=https%3A%2F%2Flcs.dynamics.com%2F
There is no Customer Source in LCS. I have a partner account!
Hope this link will be useful for you,
I can say i’m in sthe same circle:
from http://technet.microsoft.com/en-us/library/dn268616.aspx if i click on Downloadable tools http://technet.microsoft.com/en-us/library/hh378081.aspx where the last one is Test Data Transfer Tool (beta) for Microsoft Dynamics AX 2012 and the link goes to http://technet.microsoft.com/en-us/library/hh394894.aspx where in the firts paragraph is writtne:
The Test Data Transfer Tool (beta) has been moved. It is now available from the Downloadable tools section of Microsoft Dynamics Lifecycle Services.
Sorry to keep bothering you but i have never seen something so inconsistent.
Thanks!
But As today I tried to download but there is no download link.
please can anyone guide me to direct download link?
jatinrdave, you’re reopening a pretty old question. If you’re not asking about AX 2012 R2, please create a new thread with appropriate title and tags and we’ll discuss it there.
If you’re still looking for AX 2012 R2, I’m not sure if you’ll find anything. The solution demo files on PartnerSource seems to be for AX 2012 R3 and AX 2012 R3 CU9, not for older versions (R2 was released in 2012).
Martin,
Thanks for the note.Issue is solved.
