Hi all how to export import data file?
both are the same objects (either CSide object or my own extension object)
I want to export - import our demo data
how to resolve this?
it will not work. the import and export to a datafile only works when the import and export database are on the same version. What you are doing is really not a backup, and should never be treatead as a backup.
Your best possible solution is to use RapidStart…
so for the posted data (cust ledger, gen ledger ,etc) cant be migrated?
If you have a Dynamics Partner License then yes.
