I did what you say but same results, sme error. It looks like , if import has been sucessfull one time and you delete entries to retry again , it does not work. am i right? Apparently import has been deleted by someone and when I am trying now , no sucess at all.
No, you can import as often as you like (I did this today for a customer until the numbers were correct). This still points to an error on the excel sheet.
Did you turn on the debugger to find out where the error occurs?
Hello all, just recently I had the exact same error for someone I know on NAV 2009 Classic. What they claim to have did was use last years budget excel spreadsheet and add new columns in i.e. dimensions and import the excel spreadsheet (format has changed now remember, now they have extra column(s) into a new budget with a new name ie. last years was 2014/2015 and so the new budget has name 2015/2016. After digging around, debugging, we followed the steps of the manual.
Turns out that the best practice is to create a budget, export spreadsheet (do not use last years), update newly exported spreadsheet, and import. This worked fine in our case.
As per manual, follow the instructions… theres not many bug fixes around this area I would have thought so is a solid functional area.
It may not be the same issue for bof4all because they using NAV 4.0 SP3 but just that II’d share this with the community
