How to Write a report that Exports all the images stored in Employee record to C: drive? please help me |
Hi
1.Create a report with Employee table as your data Item
2.Create a text variable and name it Destination
3.go to the OnAftergetRecord() of your data item and place the below code
Employee.CALCFIELDS(Employee .);
IF Employee.).HASVALUE THEN
Begin
Destination := ‘C:\Songs\’+Employee.Code+’Bmp’;
Employee.).EXPORT(Destination,FALSE);
End;
- Go to the report properties and change the ProcessingOnly property to yes
5.Create a folder at c drive and name it Songs
6.run your report
Jerome Marshal.J
Wat is the meaning of picture field bro…?
Your requirment is export all the images from employee table na so that employee table must have field with data type blob
where ever i mentioned Employee. you select that blob field from the employee table
Thank you Verymuch Bro,its working.
i want more support from u .where r u from and for which company u r working?
Thanks&Regards,
Veeraprasadgupta,
Navision Trainee,
Hyderabad…
hey bro that is 6.1 version of navision.that employee table is from cronus company
