we have installed the FRx 6.7(SP10)… client reported that they are not able to increase the Length of Dimension.
can anyone help me, how to get it… any help would be appriciated…
thanks,
Valeru.
thanks,
Valeru.
does anyone have an idea???
Finally done!!!
I have done new Dimension setup …below are the steps.
Start the Microsoft FRx Dimension Wizard. You must enter values in the Data source type and Server name boxes. Then, select the Database and Company values. Click Next.
Click Advanced, click Metadata, and then click Next.
Click Browse, and then select the FRxVirtualMap.xml file. If the configuration is correct, you receive a message that the file is ready for processing. Click Process.
When you receive a message that states that the process is complete, click Next.
Click Standard, and then click Dimension Structures. Click Next.
A list of the dimensions and the default length of the dimensions appears. If you must increase the dimension length, type a new value in the New Length column. Click Next.
Click New Task, click Dimension Structures, and then click Next.
Click New to configure the dimension structure. In the Available dimensions column, select the dimensions that you want to report on, insert the dimensions into the Selected dimensions column, and then click Next.
Click Finish to complete the wizard.
thanks,
Valeru.
