Hi All. I know vs2008 can design rdlc report from object designer, But now we upgrade navision to 2016 from 2009, And now I can not open rdlc report from object designer in navision 2016? there is no way to do it ?
thanks in advance!
thanks in advance!
You can. Go to the Report → Design → View → Layout. This will open visual studio to design rdlc report.
Make sure before doing this you choose in NAV Tools → Options → Use Report Builder = No.
Hi Harikiran , I know how to open vs to design the report, I have installed vs2010, But when I open layout, it saids “A supported version of visual studio could not be found”, if I lost some componets when I installing vs2010?
Hi Gary,
You cannot use Visual Studio 2010 with Dynamics NAV 2016. The requirements to edit report layouts in 2016 are:
And if you have installed NAV 2016 CU1 (or later), then you can also use the free Visual Studio 2015 Community Edition to edit your report layouts.
I see., thanks Erik.
