IF ELSE
Hi
I want or condition in IF ELSE statement
e.g. IF a=5 or a=2 then
else
Is it possible ???
Thanx.
Yes, this is no problem, just encapsulate your statements in brackets:
IF (a=5) OR (a=2) THEN
ELSE
If the above doesn’t work, then Perhaps you will need 1 more bracket:
IF ( (a=5) OR (a=2) ) THEN
ELSE
Thanks…
Hi Jolly,
please do “Verify the solution” which helped you to solve the problem. This earns you points and also credits the poster of the correct answer.
